345
how to handle ComboBox selection change within xamdatagrid
I have xamdatagrid and within this grid there is a column which is of type combobox. Now based upon certain condition when I change the selection of the comobobox a new record should get added within the Grid. Please suggest if I need to add trigger to the combobox upon selectionchanged and raise and event in that case I would need the index of currently grid row selected and index of combov=box selected item.
Please advise how can achive the above.
Below is the xaml code:
<UserControl x:Class="DLVR.IndividualPositionReport.Visualisation.Views.AggreagteCalcParamCollectionView"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:local="clr-namespace:DLVR.IndividualPositionReport.Visualisation.Views"
xmlns:bmg="clr-namespace:DLVR.IndividualPositionReport.Visualisation.BenchmarkGrid"
xmlns:bm="clr-namespace:DLVR.IndividualPositionReport.Visualisation.CompensationBlock"
xmlns:vp="clr-namespace:DLVR.Shared.BaseClasses.VisualisationParameters;assembly=DLVR.Shared"
xmlns:idp="http://infragistics.com/DataPresenter"
xmlns:i="http://schemas.microsoft.com/expression/2010/interactivity"
xmlns:ig="http://infragistics.com/Editors"
mc:Ignorable="d"
d:DesignHeight="300" d:DesignWidth="300">
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="Auto"></RowDefinition>
<RowDefinition Height="*"></RowDefinition>
</Grid.RowDefinitions>
<Grid.Resources>
<Style x:Key="textField" TargetType="{x:Type idp:CellValuePresenter}">
<Setter Property="ContentTemplate">
<Setter.Value>
<DataTemplate>
<ItemsControl ItemsSource="{Binding Path=DataContext.DataItem.Value.Parameters,RelativeSource={RelativeSource Mode=FindAncestor,AncestorType={x:Type idp:CellValuePresenter}}}" DataContext="{Binding Value,Mode=OneWay}">
<i:Interaction.Triggers>
<i:EventTrigger EventName="SelectionChanged">
<i:InvokeCommandAction CommandParameter="{Binding Path=DataContext.DataItem}" Command="{Binding DataContext.SelectChangeCommand, RelativeSource={RelativeSource Mode=FindAncestor,AncestorType={x:Type idp:CellValuePresenter}}}"/>
</i:EventTrigger>
</i:Interaction.Triggers>
<ItemsControl.ItemTemplate>
<DataTemplate>
<ig:XamTextEditor Value="{Binding Value}">
<ig:XamTextEditor.Template>
<ControlTemplate>
<TextBlock Text="{Binding Value,Mode=TwoWay,UpdateSourceTrigger=PropertyChanged}"></TextBlock>
</ControlTemplate>
</ig:XamTextEditor.Template>
<ig:XamTextEditor.EditTemplate>
<ControlTemplate>
<TextBox Text="{Binding Value, Mode=TwoWay,UpdateSourceTrigger=PropertyChanged}"></TextBox>
</ControlTemplate>
</ig:XamTextEditor.EditTemplate>
</ig:XamTextEditor>
</DataTemplate>
</ItemsControl.ItemTemplate>
<ItemsControl.ItemsPanel>
<ItemsPanelTemplate>
<StackPanel></StackPanel>
</ItemsPanelTemplate>
</ItemsControl.ItemsPanel>
</ItemsControl>
</DataTemplate>
</Setter.Value>
</Setter>
</Style>
<Style x:Key="combo" TargetType="{x:Type idp:CellValuePresenter}">
<Setter.Value>
<DataTemplate>
<ComboBox ItemsSource="{Binding Path=DataContext.DataItem.Options,RelativeSource={RelativeSource Mode=FindAncestor,AncestorType={x:Type idp:CellValuePresenter}}}"
DisplayMemberPath="Label"
SelectedItem="{Binding Path=DataContext.DataItem.Value,Mode=TwoWay,UpdateSourceTrigger=PropertyChanged,RelativeSource={RelativeSource Mode=FindAncestor,AncestorType={x:Type idp:CellValuePresenter}}}">
</ComboBox>
</DataTemplate>
</Setter.Value>
</Setter>
</Style>
</Grid.Resources>
<StackPanel Grid.Row="0" Orientation="Horizontal" HorizontalAlignment="Center">
<Button Content="Add Row" Width="100" Margin="0,0,20,0" Command="{Binding AddNewRowCommand}"></Button>
<Button Content="Delete Row(s)" Width="100" Command="{Binding DeleteRowCommand}"></Button>
</StackPanel>
<StackPanel Orientation="Horizontal" Grid.Row="1">
<CheckBox IsChecked="{Binding IsVarianceChecked}" Width="Auto" Command="{Binding VarianceCommand}"/>
<TextBlock Text="Show variance from Sponsor" Width="Auto"/>
</StackPanel>
<idp:XamDataGrid x:Name="td" Grid.Row="2"
DataSource="{Binding FilteredCalcParameter,Mode=TwoWay,UpdateSourceTrigger=PropertyChanged}"
SelectedDataItems="{Binding SelectedRows,Mode=TwoWay,UpdateSourceTrigger=PropertyChanged}"
SelectedDataItemsScope="RecordsOnly"
IsSynchronizedWithCurrentItem="True">
<idp:XamDataGrid.FieldLayoutSettings>
<idp:FieldLayoutSettings AutoGenerateFields="False"
></idp:FieldLayoutSettings>
</idp:XamDataGrid.FieldLayoutSettings>
<idp:XamDataGrid.FieldLayouts>
<idp:FieldLayout>
<idp:FieldLayout.Fields>
<idp:UnboundField BindingPath="Value" Label="Calculation" CellValuePresenterStyle="{StaticResource ResourceKey=combo}">
</idp:UnboundField>
<idp:UnboundField BindingPath="Value" Label="Parameter (where applicable)" BindingMode="TwoWay" CellValuePresenterStyle="{StaticResource ResourceKey=textField}">
</idp:UnboundField>
</idp:FieldLayout.Fields>
</idp:FieldLayout>
</idp:XamDataGrid.FieldLayouts>
</idp:XamDataGrid>
</Grid>
</UserControl>
  • 16495
    Hello Richa,
    You  can handle ComboBox's SelectionChanged event directly in your xaml decalration for it, then in the event handler you can add new item in XamDataGrid's DataSource collection. To access the DataRecordPresenter, where the ComboBox is located you can use GetAncestorFromType method of our Utilities class, this way you will be able to access current Record's index. I have attached a simple sample application, where you can test this approach.
    Sincerely,
    Zhivko
    Associate Software Developer
    DataGrid_ComboSelectionMVVM.zip
