I've got the same problem with XamNumericEditor and XamMaskedEditor. I use Infragistics version 16.2.
After mouse click the focused element look like this, how it should look:
But if i run the app on a Touchscreenmonitor and i touch at the control the focused element looked like this:
But i want that the focued style is at both scenes like the fist picture. I don't want the borders and the minimized fontsize.
If i put a normal Textbox inside there is no border around drawn by the system. How can i handle the problem?
XAML:
<Custom:XamNumericEditor Name="NumericEditor" Value="{Binding InputValue, Mode=TwoWay, RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type UserControl}}, UpdateSourceTrigger=LostFocus, NotifyOnTargetUpdated=True}" Format="{Binding InputFormat, Mode=TwoWay, RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type UserControl}}}" Mask="{Binding InputMask, Mode=TwoWay, RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type UserControl}}}" VerticalAlignment="Top" PromptChar="" IsEnabled="{Binding ElementName=InputControl, Path=IsEnabled}" Background="{StaticResource TransparentBrush}" IsReadOnly="{Binding IsReadonly, ElementName=InputControl}" LostFocus="NumericEditor_LostFocus"> <Custom:XamNumericEditor.Style> <Style TargetType="Custom:XamNumericEditor"> <Setter Property="BorderThickness" Value="0" /> <Setter Property="Foreground" Value="{StaticResource ScheugenpflugBlue}" /> <Setter Property="FontSize" Value="25px" /> <Setter Property="HorizontalContentAlignment" Value="Left" /> <Setter Property="VerticalAlignment" Value="Bottom" /> <Setter Property="FontWeight" Value="Bold" /> <Setter Property="SpinButtonDisplayMode" Value="Never" /> <Style.Triggers> <DataTrigger Binding="{Binding ElementName=InputControl, Path=IsEnabled}" Value="False"> <Setter Property="Foreground" Value="{StaticResource ForegroundDisabledBrush}" /> </DataTrigger> <DataTrigger Binding="{Binding ElementName=InputControl, Path=IsReadonly}" Value="true"> <Setter Property="Foreground" Value="{StaticResource ForegroundBrush}" /> <Setter Property="IsHitTestVisible" Value="False" /> </DataTrigger> </Style.Triggers> </Style> </Custom:XamNumericEditor.Style> </Custom:XamNumericEditor>
Serencly,
Andreas
Error from an external package.
Closed!
The pictures are removed by the infragistics system....
1)
See picture at first post on the left side for the normal focused style
2)
See picture at first post on the right side for the wrong focused style
