105
Different margin of header text
Hello.
There are grid below. I need to set one margin of header text in first and last colmns and another margin of header text in others columns. I tried to do
it by implementing DataTrigger in LabelPresenterStyle, but it doesn`t work. How can I do it?
<Style TargetType="{x:Type igDP:LabelPresenter}" BasedOn="{StaticResource LabelPresenterStyle}" >
<Style.Setters>
<Setter Property="FontFamily" Value="Segoe UI"/>
<Setter Property="BorderThickness" Value="1,0,1,0"/>
<Setter Property="OuterBorderBrush" Value="White"/>
<Setter Property="FontSize" Value="16"/>
<Setter Property="Foreground" Value="{StaticResource MetroHyperlinkForegroundColor}"/>
<Setter Property="Background" Value="{StaticResource MetroWindowFooterBackgroundColor}"/>
<Setter Property="ContentTemplate">
<Setter.Value>
<DataTemplate>
<TextBlock Name="textBlock" Margin="8,0,8,0" Text="{TemplateBinding Content}"/>
<DataTemplate.Triggers>
<DataTrigger Binding="{Binding Path=Field, RelativeSource={RelativeSource AncestorType={x:Type igDP:LabelPresenter}}}" Value="Field: OrderNumber">
<Setter TargetName="textBlock" Property="TextBlock.Margin" Value="16,0,16,0"/>
</DataTrigger>
<DataTrigger Binding="{Binding Path=Field, RelativeSource={RelativeSource AncestorType={x:Type igDP:LabelPresenter}}}" Value="Field: Comment">
</DataTrigger>
</DataTemplate.Triggers>
</DataTemplate>
</Setter.Value>
</Setter>
</Style.Setters>
</Style>
<igDP:XamDataGrid Name="DataGrid"
GroupByAreaLocation="None"
DataContext="{Binding}"
DataSource="{Binding Path=Attachments}"
ActiveDataItem="{Binding Path=SelectedAttachment, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}"
HorizontalAlignment="Stretch"
VerticalAlignment="Stretch"
AutoFit="True"
<i:Interaction.Behaviors>
<behaviors:XamDataGridSelectedItemsBehavior SelectedItems="{Binding Path=SelectedItems}" />
</i:Interaction.Behaviors>
<i:Interaction.Triggers>
<i:EventTrigger EventName="MouseDoubleClick">
<triggerActions:InvokeDelegateCommandAction Command="{Binding Path=DoubleClickCommand}" />
</i:EventTrigger>
</i:Interaction.Triggers>
<igDP:XamDataGrid.FieldSettings>
<igDP:FieldSettings AllowEdit="False"
AllowFixing="No"
LabelTextAlignment="Center"
LabelTextTrimming="CharacterEllipsis"
LabelTextWrapping="NoWrap"
SortComparisonType="CaseInsensitive"
CellClickAction="SelectRecord"
AllowRecordFiltering="False"/>
</igDP:XamDataGrid.FieldSettings>
<igDP:XamDataGrid.FieldLayoutSettings>
<igDP:FieldLayoutSettings HeaderPresenterStyle="{StaticResource HeaderStyle}" AllowDelete="False" AutoGenerateFields="False" SelectionTypeRecord="Extended" HighlightAlternateRecords="True"
SelectionTypeField="none" RecordSelectorLocation="None" HeaderPlacementInGroupBy="OnTopOnly" ResizingMode="Immediate" SelectionTypeCell="None"
DataRecordCellAreaStyle="{StaticResource DataRecordStyle}" DataRecordPresenterStyle="{StaticResource DataRecordPresenterStyle}">
</igDP:FieldLayoutSettings>
</igDP:XamDataGrid.FieldLayoutSettings>
<igDP:XamDataGrid.FieldLayouts>
<igDP:FieldLayout IsDefault="False" >
<igDP:Field Name="OrderNumber" Label="OrderNumber" AllowEdit="True" Width="auto" >
<igDP:Field.Settings>
<igDP:FieldSettings CellValuePresenterStyle="{StaticResource NumberCell}" FilterOperandUIType="Default" FilterOperatorDefaultValue="Contains" FilterOperatorDropDownItems="Contains" />
</igDP:Field.Settings>
</igDP:Field>
<igDP:Field Name="State" Label="State" Width="auto" >
<igDP:FieldSettings CellValuePresenterStyle="{StaticResource StatusAtachmentCell}" FilterOperandUIType="Default" FilterOperatorDefaultValue="Contains" FilterOperatorDropDownItems="Contains" />
</igDP:Field>
<igDP:Field Name="FileName" Label="Document">
<igDP:FieldSettings CellValuePresenterStyle="{StaticResource DocumentAtachmentCell}" FilterOperandUIType="Default" FilterOperatorDefaultValue="Contains" FilterOperatorDropDownItems="Contains" />
</igDP:Field>
<igDP:Field Name="Type" Label="Type" Width="auto">
<igDP:FieldSettings CellValuePresenterStyle="{StaticResource TypeAtachmentCell}" FilterOperandUIType="Default" FilterOperatorDefaultValue="Contains" FilterOperatorDropDownItems="Contains" />
</igDP:Field>
<igDP:Field Name="Foundation" Label="Foundation">
<igDP:FieldSettings CellValuePresenterStyle="{StaticResource FoundationAtachmentCell}" FilterOperandUIType="Default" FilterOperatorDefaultValue="Contains" FilterOperatorDropDownItems="Contains" />
</igDP:Field>
<igDP:Field Name="CountSign" Label="Signature Count" Width="auto">
<igDP:FieldSettings CellValuePresenterStyle="{StaticResource CountSignAtachmentCell}" FilterOperandUIType="Default" FilterOperatorDefaultValue="Contains" FilterOperatorDropDownItems="Contains" />
</igDP:Field>
<igDP:Field Name="Comment" Label="Comment" >
<igDP:FieldSettings CellValuePresenterStyle="{StaticResource CommentAtachmentCell}" FilterOperandUIType="Default" FilterOperatorDefaultValue="Contains" FilterOperatorDropDownItems="Contains" />
</igDP:Field>
</igDP:FieldLayout>
</igDP:XamDataGrid.FieldLayouts>
</igDP:XamDataGrid>
