250
Selected Item?
List<Employee> employees = Service.GetEmployees();
xamDataGrid1.DataSource = employees;
 How can I get  the selected item in terms of an Employee object.. the docs only mention get the selected row and then retrieving stuff via cell values...
 Found solution:
PersonEntity selectedPerson = ((Infragistics.Windows.DataPresenter.DataRecord)(xamDataGrid1.SelectedItems.Records[0])).DataItem as PersonEntity;
  • 4850
    Note that selection and activation are 2 separate concepts in the XamDataGrid. You can have 0 or more selected records at any time but there is only ever 1 active record.
    If you are interested in the selected records then the solution you describe should work. If you want the active record then do this:
    PersonEntity pe = null;
    DataRecord dr = XamDataGrid1.ActiveRecord as DataRecord;
    if ( dr != null ) pe = rd.DataItem as PersonEntity;
    etc.
    Note: the reason that you need to cast to a DataRecord is because ActiveRecord returns the Record base class since it could also be an instance of a GroupByRecord or an ExpandableFieldRecord.
