Hello
I have attached error log file.
The error is encountered when i drag row from XamDataGrid and drop on Column header of same grid result is my application get crashed.
I am using InfragisticsWPF4.v13.1
Can you suggest any solution?
Thanks in advance,
Pruthviraj
Hello Pruthviraj,
I would like to add a suggestion to test your sample application with the latest Service Release for 13.1, just in case if it has been an issue that is fixed in the latest Service Release.
Thank you for choosing Infragistics.
Since WPF version 13.1 is no longer supported (please see the Product Lifecycle page) the best I can suggest is to download and test your application with the WPF version 17.1.
If you are able to reproduce the same issue for the drag and drop in XamDataGrid with version 17.1, it would be best if you could provide us with a small isolated sample, where the issue is reproduced. This way we can run it and use it for a local debugging. If you are unable to provide an isolated sample we may be able to give suggestions if you provide the code that you are using.
