225
ItemClicked Event is not firing
ItemClikcked event is not firing when i click any xammenu item with mouse. It is firing only when i enter mouse. Can you please provide resolution for this.
Note: I am using Hierarchial data template for showing multi level data.
  • 6365
    Verified Answer
    Hello viswa,
    I tested the behavior you have described in regards to the ItemClicked event of the XamMenu not firing when using a hierarchical data template and I was not able to reproduce it.
    I have attached a sample application that adds an item to a ListBox whenever the ItemClicked event is fired. Would you please modify it so the issue is reproduced and send it back to me? Having this information will help me further investigate this matter for you.
    If you have any questions, please let me know.
    XamMenu_sample.zip
