Hi
We have noticed an issue of tooltip showing at wrong position when using a scrollviewer outside the XamDataChart.
The position of the axis is displaced form the position of the mouse and this position keeps growing as the scroll position increases.
This problem is evident when the width(viewport) of the chart within the scrollviewer is greater than the screen width.
Has any one else faced this problem?
Is there a workaround to go with this is happening with infragistics 14.1.
( Screen shots attached)
Neeraj
Hi Neeraj,
We don't have any other reports for such erroneous behavior.
I saw that you're asking about Infragistics 14.1. Could you please try the same behavior with the latest Infragistics 17.1? If the issue persist could you try to isolate it in a simple sample application and attach it here so we can investigate it.
Thank you in advance for your cooperation.
Sincerely,
Borislav Kulov
Infragistics team
