30
Change Cell and Row Color when cell updated
I have a DataGrid with a dataSource binding to a collection.
A trigger with a CellUpdated event.
The method that is called as soon as you make a change to the cell is in my ViewModel.
I want to change the color of the cell and row concerned as soon as there is change
.xaml :
.cs :
public void XamDataGridCellUpdated(object sender, CellUpdatedEventArgs e)
       var xamDataGrid = sender as XamDataGrid;
How could I do ?
Thanks for any thoughts.
  • 16495
    Verified Answer
    Offline posted in reply to Lepage
    Hello Lepage,
    You can use the approach from the following forum thread in order to change the cell background:
    https://es.infragistics.com/community/forums/t/14111.aspx
    1. Use the Tag property on the Cell, so in the CellUpdated event set Cell.Tag to a Boolean true .
    2. Bind the Tag of the CellValuePresenter to a multibinding that binds to the CellValuePresenter's Field and Record
    to obtain the Cell and then set the CellValuePresenter style trigger to bind to the Tag.Tag(i.e. Cell.Tag) .
    <Style TargetType="{x:Type igDP:CellValuePresenter}">
                <Setter Property="Tag">
                    <Setter.Value>
                        <MultiBinding Converter="{StaticResource fieldRecordToCell}">
                            <Binding RelativeSource="{RelativeSource Self}" Path="Field" />
                            <Binding RelativeSource="{RelativeSource Self}" Path="Record" />
                        </MultiBinding>
                    </Setter.Value>
                </Setter>
                <Style.Triggers>
                    <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Tag.Tag, Converter={StaticResource keepChangedCellStyle}}" Value="True" >
                        <Setter Property="Background"  Value="Yellow"/>
                    </DataTrigger>
                </Style.Triggers>
    </Style>
    I have attached a simple sample application, where you can test this approach.
    Sincerely,
    Zhivko
    Associate Software Developer
    CellUpdated_Background.zip
  • 30
    Verified Answer
    Sorry, I forgot .xaml
    .xaml :
    <igDP:XamDataGrid Name="XamDataGridTableData" DataSource="{Binding TableData}">
         <i:Interaction.Triggers>
              <i:EventTrigger EventName="CellUpdated" x:Name="interactivityFix" SourceName="XamDataGridTableData">
                   <ei:CallMethodAction x:Name="interactionsFix" MethodName="XamDataGridCellUpdated" TargetObject="{Binding}"/>
              </i:EventTrigger>
         </i:Interaction.Triggers>
    </igDP:XamDataGrid>
    .cs :
    How could I do ?
