how can I change the color/opacity of the outer part of the dragzoom area?
The contrast between dragzoom area und outer part will be way to weak e.g. if I have a red plot area background
BR,
Hendrik
Hi Andrew,
thank you that did the trick.
Hello Hendrik,
In order to change the color and opacity of the outer part of the drag-zoom area, I would recommend utilizing the PreviewPathStyle property of the XamDataChart. This property accepts a Style targeting a Path element, and setting the Fill and Opacity properties will allow you to change the color and opacity of the area outside of the preview zoom rectangle.
Some sample code to do this could look like the following:
<ig:XamDataChart.PreviewPathStyle> <Style TargetType="{x:Type Path}"> <Setter Property="Fill" Value="Red"/> <Setter Property="Opacity" Value=".5"/> </Style></ig:XamDataChart.PreviewPathStyle>
Sincerely,AndrewAssociate Developer
