1080
xamdoc manager split cursor on windows10
Hello, the WPF xamdocmanager split cursor on a Windows 10 system with a display setting set to 3200x1800 appears almost invisible.
Any way to show it at the default size?
  • 29105
    Hello famproject,
    Thank you for contacting Infragistics. It's possible that this behavior is a result from the Cursor exposing a "scaletoDPI" which could have been overlooked on our part. And this behavior, in thoery, could be affected in other areas as well aside from the XamDockManager. We don't have a viable work around at the moment and would like to address the behavior.
    I've informed my team and logged a development issue for someone to investigate this further. I have created case for you with ID CAS-182466-X6K3Q6 . You could reach your case following the link bellow:
    https://es.infragistics.com/my-account/support-activity
    I will update you via the mentioned case, so if you have any further questions or comments please update your case.
