195
XamPropertyGrid bound to PropertyGridPropertyItem(s)
Is there a way to bring the SelectedItem item into focus in the property grid after being set.
The Grid in xaml below:
<igProp:XamPropertyGrid x:Name="XamPropertyGrid" Grid.Row="1" Grid.Column="2" Margin="2,0,0,3" NameColumnWidth="350" AllowDrop="True"
SelectedObject="{Binding ElementName=SpSmTreeView2, Path=ActiveDataItem}"
SelectedItem="{Binding Path=DataContext.SelectedProperty, Mode=TwoWay, RelativeSource={RelativeSource Mode=FindAncestor, AncestorType=UserControl}}" >
private PropertyGridPropertyItem _selectedProperty;
public PropertyGridPropertyItem SelectedProperty
get
return _selectedProperty;
set
if (_selectedProperty != value)
_selectedProperty = value;
RaisePropertyChanged(() => SelectedProperty);
Also, is the following code the propert way to set the SelectedProperty when the grid is bound to PropertyGridPropertyItem(s)
var PropertyGridPropertyItem = new PropertyGridPropertyItem(SelectedBluePrintObject as BluePrintViewModel, theMissingSPPropertyName, theSPProperty.CategoryName, typeof(String), theSPProperty.IsReadOnly, false);
SelectedProperty = PropertyGridPropertyItem;
Any help will be appreciated.  Also, is there a way to insert code snippets with better formatting?  Thank you,
Andy
