Is it possible to have some kind of HierarchyDescriptor similar to "All Products" that would show the total only for the selected cells?
Thanks.
Hello,Thank you for the provided screenshot illustrating the calculating of the totals that you are trying to achieve.The Totals are calculated based on the data and the hierarchy level descriptors. This being said, the total could be calculated by adding level descriptors as it was described at http://es.infragistics.com/community/forums/p/91624/452917.aspx#452917.In a scenario where the totals should be calculated based on the currently selected cells, it could be helpful to use custom aggregators instead. I am currently working on this approach and will update you with my findings.
Thanks, hadn't seen that tab.
On the attached screenshot you can see that the total number of units across all cities is 7+9+8+6 = 30.
If I just select the NumberOfUnits for City2 (8) and City3(6), is it possible to have a cell displaying 14?
There is an options tab where you can attach a file. Just like when attaching a sample project for example.
M.Yovchev
How can I upload a screenshot from my local PC? The "Insert/Edit image" option seems to expect an internet URL.
The option with the hierarchy descriptor is not possible. Can you please provide a screenshot that explains what is the scenario.
