100
Time Consumtion in Checking Child Nodes of XamdataTree
I have a XamDataTree , which has more than 500 child nodes.
But When I check the checkbox of PArent Node , It takes huge amount of time in checking the child nodes
Is it possible or a way to reduce this time ?
  • 16495
    Hello Ankit,
    I followed the scenario you have suggested  and was unable to reproduce the behavior about time consummation issue when checking nodes. I have attached the sample project I used to test this.  Please test this project on your PC, whether or not it works correctly may help indicate the nature of this problem.
    If the project does not work correctly, this indicates either a problem possibly specific to your environment, or a difference in the DLL versions we are using.  My test was performed using version 16.1 – 2162 and 16.2 – 2030 of WPF product.
    If the project does show the product feature working correctly, this indicates a possible problem in the code of your application.  It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing. Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
    Please let me know if I can provide any further assistance.
    Sincerely,
    Zhivko
    LargeChildrenNodeCheckingsIssue.zip
