Hi, I'm using the zoom feature of xamDataChart and trying to customize it, please advise:
I would like the zoom to be only on x axis , I've set only horizontal and it is works fine
1. While dragging on the chart to zoom in, I get a dashed-rectangle based on the position I've started the drag until the end position, but I would like to see only X axis being selected and not Y axis. that is, upper and lower lines of the rectangle should always be on top and bottom of the chart - as there is no meaning to selecting part of the y axis in this case.
2. I want to change the label appearance once I zoom. that is, when the zoomed in range is hour, show time by minute, if range is minute, show seconds, etc. I have the event but I could not find how to calculate the viable range for this matter.
Thanks.
Hello eligazit,
It appears that this forum thread is a duplicate to the one authored by you that I have just recently answered. For reference, the other forum thread can be found here: http://es.infragistics.com/community/forums/t/108204.aspx.
As this one is a duplicate, I will be marking this thread as closed. If you need further assistance, I will be happy to assist you on the other thread.
Sincerely,AndrewAssociate Developer
