Hi team,
I have Xamdatagrid. There are 6-7 columns in grid.
My first column values are lengthy and I want to add vertical scrollbar for first column values.
Please help.
Hello Sarita,
Unfortunately I do not see any references in your post. Can you please copy paste the references in textual format. Basically you need to add the same assembly references as in the sample I attached in my previous post. What version of the controls are you using?
Sincerely,
Radko
Senior Software Developer
Thanks for your reply.
I ran your solution and it works.
But when I am trying to add same code to my xaml, I am receiving build error.
Build error is "The type igEditors:TemplateEditorValueBinding not found. You are missing assembly reference."
My solution has below references.
Pl
I am attaching a sample which demonstrates how to add scrollbars to the first column in a xamDataGrid. The sample adds scrollbars for both display and edit mode and you can use both or just one of them depending on your application scenario. For comparison all three columns are containing lengthy data, but only the first column has scrollbars.
Please do not hesitate to let me know if you have any further questions on this matter.
