535
Problem with formula applied to a WorksheetRegion
I need to apply a formula into the selected WorksheetRegion. I'm using the following code to achieve this:
var selectionRange = _grid.ActiveSelection.CellRanges.First();
formula.ApplyTo(new WorksheetRegion(_grid.ActiveWorksheet, selectionRange.FirstRow, selectionRange.FirstColumn, selectionRange.LastRow, selectionRange.LastColumn));
It works well, except when I try to copy and paste the resulting data. A couple of copy/pastes causes the following null reference exception:
System.NullReferenceException: Object reference not set to an instance of an object.
at Infragistics.Documents.Excel.Serialization.BIFF8.Biff8RecordStream.WriteRefU(WorksheetRegion region)
at Infragistics.Documents.Excel.Serialization.BIFF8.BiffRecords.SHRFMLARecord.Save(WorkbookSaveManagerExcel2003 saveManager)
at Infragistics.Documents.Excel.Serialization.WorkbookSaveManagerExcel2003.WriteRecord(BIFF8RecordType type)
at Infragistics.Documents.Excel.Serialization.BIFF8.BiffRecords.FORMULARecord.SaveCellValue(WorkbookSaveManagerExcel2003 saveManager, MemoryStream initialData)
at Infragistics.Documents.Excel.Serialization.WorkbookSaveManagerExcel2003.WriteCellRecord()
at Infragistics.Documents.Excel.Serialization.WorkbookSaveManagerExcel2003.<>c__DisplayClass15.<>c__DisplayClass17.<WriteWorksheetRowBlock>b__12(CellDataContext cellDataContext)
at Infragistics.Documents.Core.Async.ForEachSliceHelper`1.ExecuteNext()
at Infragistics.Documents.Core.Async.Try(Func`1 try, Action finally)
at Infragistics.Documents.Excel.Serialization.WorkbookSaveManagerExcel2003.<>c__DisplayClass15.<WriteWorksheetRowBlock>b__11(WorksheetRow row)
at Infragistics.Documents.Core.Async.ForEachHelper`1.ExecuteNext()
at Infragistics.Documents.Core.WorkItem.WorkItemAsync.ExecuteCore(WorkItemScheduler scheduler)
at Infragistics.Documents.Core.WorkItem.Execute(WorkItemScheduler scheduler)
--- End of stack trace from previous location where exception was thrown ---
at TryThrowExceptionDispatchInfo(Object )
at Infragistics.Documents.Core.WorkItem.ExceptionInfo.Rethrow()
at Infragistics.Documents.Core.WorkItemExtensions.GetResult[TResult](WorkItem`1 this)
at Infragistics.Documents.Excel.Serialization.WorkbookSaveManagerExcel2003.<>c__DisplayClass21.<WriteWorksheetRowBlocks>b__1f(WorkItem`1 t)
at Infragistics.Documents.Core.WorkItem.WorkItemSync.ExecuteCore(WorkItemScheduler scheduler)
at Infragistics.Documents.Excel.Serialization.WorkbookSaveManagerExcel2003.<>c__DisplayClassc.<SaveWorksheet>b__b(WorkItem`1 t)
at Infragistics.Documents.Core.WorkItemExtensions.<ExecuteWithDefaultScheduler>b__0(WorkItem t)
at Infragistics.Documents.Core.WorkItem.RunNextWorkItem(WorkItemScheduler scheduler)
at Infragistics.Documents.Core.WorkItemScheduler.SynchronousImpl.Execute(WorkItem workItem)
at Infragistics.Documents.Excel.Workbook.Save(Stream stream, WorkbookSaveOptions saveOptions)
at Infragistics.Controls.Grids.Core.IGExcelSerializationProvider.Save(WorkbookDataObjectSaveContext context)
at Infragistics.Controls.Grids.Core.WorkbookDataObjectManager.CreateDataObject(Boolean isDragDrop)
at Infragistics.Controls.Grids.Core.WorkbookDataObjectManager.CopyToClipboard()
at Infragistics.Controls.Grids.Core.Spreadsheet.ExecuteCommand(SpreadsheetCommandType command, Object commandParameter, Object sourceElement, Int64 currentState)
at Infragistics.Controls.Grids.Core.Spreadsheet.ProcessKeyDown(Key key, ModifierKeys modifierKeys)
at Infragistics.Controls.Grids.XamSpreadsheet.ProcessKeyDown(KeyEventArgs e)
at Infragistics.Controls.Grids.Primitives.SpreadsheetCellEditor.OnKeyDown(KeyEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndKeyboardInputProvider.ProcessKeyAction(MSG& msg, Boolean& handled)
at System.Windows.Interop.HwndSource.CriticalTranslateAccelerator(MSG& msg, ModifierKeys modifiers)
at System.Windows.Interop.HwndSource.OnPreprocessMessage(Object param)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg)
at System.Windows.Interop.HwndSource.OnPreprocessMessageThunk(MSG& msg, Boolean& handled)
at System.Windows.Interop.ThreadMessageEventHandler.Invoke(MSG& msg, Boolean& handled)
at System.Windows.Interop.ComponentDispatcherThread.RaiseThreadMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at Desktop.App.Main()
