Hi, I created a ribbon using Office2013 theme and an application menu mode of Office2010, but for some reason my application menu's subitems are barely visible. If you run the sample I have attached, and select the tab "Menu", and then "SubMenu A", you will notice that only the last item (Submenu A - item 6) is clearly visible. This is because for this item I set the ApplicationMenu2010Item.Header property explicitely to a Label instead of a string. Why is the styling so strange when the header is set to a string? It doesn't seem to me that this is the way it's supposed to look? By the way, when you hover over the items the styling is also different for strings vs. labels.
Regards, Stefan
Ok, thanks.
Hello Stefan,I created the following case for you: 'CAS-176195-M7V6K8' and will update you through it. You could see it in your account in the 'Support Activity' page.
