Hello, I have the following code and wonder why it's not working..
<Window x:Class="Wpf2.Window1" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:local="clr-namespace:Wpf2" Title="Window1" Height="276" Width="483" xmlns:my="clr-namespace:Infragistics.Windows.DataPresenter;assembly=Infragistics3.Wpf.DataPresenter.v8.1.Express"> <Grid> <Grid.Resources> <!-- Creates a DataSet with two related DataTables. --> <ObjectDataProvider x:Key="dataSetProvider" MethodName="CreateDataSet" ObjectType="{x:Type local:DataSetCreator}" /> </Grid.Resources> <my:XamDataGrid x:Name="XamDataGrid1" DataSource="{Binding Source={StaticResource dataSetProvider},XPath=Master}" > </my:XamDataGrid> </Grid></Window>
using System;using System.Data;namespace Wpf2{ public static class DataSetCreator { public static DataSet CreateDataSet() { DataSet ds = new DataSet(); // Create the parent table. // *************************************** DataTable tbl = new DataTable( "Master" ); tbl.Columns.Add( "ID", typeof( int ) ); tbl.Columns.Add( "Name" ); for( int i = 0; i < 3; ++i ) { DataRow row = tbl.NewRow(); row["ID"] = i; row["Name"] = "Master #" + i; tbl.Rows.Add( row ); } ds.Tables.Add( tbl ); // Create the child table. // *************************************** tbl = new DataTable( "Detail" ); tbl.Columns.Add( "MasterID", typeof( int ) ); tbl.Columns.Add( "Info" ); for( int i = 0; i < 9; ++i ) { DataRow row = tbl.NewRow(); row["MasterID"] = i % 3; row["Info"] = String.Format( "Detail Info #{0} for Master #{1}", (i / 3), (i % 3) ); tbl.Rows.Add( row ); } ds.Tables.Add( tbl ); // Associate the tables. // *************************************** ds.Relations.Add( "Master2Detail", ds.Tables["Master"].Columns["ID"], ds.Tables["Detail"].Columns["MasterID"] ); return ds; } }}
I got it. I should have read "the requirement for binding" in help file.
