Thanks in Advance !
Thanks for the prompt response Mircho.
Case closed.
About first question I can say that you have to select and target level so that slicer items are shown.
About second question I can say that it is possible when a custom template is applied to slicer control. You can grab the default slicer template and remove the header part or disable the combo selectors. It is not possible to disable this part of slicer control with property.
About third question I was not able to achieve this. My opinion is that applying custom template is better solution.
M.Yovchev
