465
Getting Null Reference Error at Infragistics.Windows.DataPresenter.RecordPresenter.InitializeIsAlternate()
Trying to troubleshoot an error. Can you please tell me what would cause this error?
Application will shutdown. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Windows.DataPresenter.DataItemPresenter.GetIsAlternate()
   at Infragistics.Windows.DataPresenter.DataItemPresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.DataPresenter.CellValuePresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
   at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
   at System.Windows.TreeWalkHelper.InvalidateTreeDependentProperty(TreeChangeInfo info, DependencyObject d, FrameworkObject& fo, DependencyProperty dp, FrameworkPropertyMetadata fMetadata, Style selfStyle, Style selfThemeStyle, ChildRecord& childRecord, Boolean isChildRecordValid, Boolean hasStyleChanged, Boolean isSelfInheritanceParent)
   at System.Windows.TreeWalkHelper.InvalidateTreeDependentProperties(TreeChangeInfo info, FrameworkElement fe, FrameworkContentElement fce, Style selfStyle, Style selfThemeStyle, ChildRecord& childRecord, Boolean isChildRecordValid, Boolean hasStyleChanged, Boolean isSelfInheritanceParent)
   at System.Windows.FrameworkElement.InvalidateTreeDependentProperties(TreeChangeInfo parentTreeState, Boolean isSelfInheritanceParent)
   at System.Windows.FrameworkElement.OnAncestorChangedInternal(TreeChangeInfo parentTreeState)
   at System.Windows.TreeWalkHelper.InvalidateOnTreeChange(FrameworkElement fe, FrameworkContentElement fce, DependencyObject parent, Boolean isAddOperation)
   at System.Windows.FrameworkElement.ChangeLogicalParent(DependencyObject newParent)
   at System.Windows.FrameworkElement.AddLogicalChild(Object child)
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.AddChild(FrameworkElement child)
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.CreateCellElement(Int32 index, Field field, Boolean useCellPresenter, Nullable`1 isMouseOverCellArea)
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.ReuseCellElements(IList`1 newVirtFields, IList`1 newNonVirtFields)
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.VerifyFieldLists()
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.OnScrollVersionChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue)
   at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange)
   at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)
   at System.Windows.Data.BindingExpression.ScheduleTransfer(Boolean isASubPropertyChange)
   at MS.Internal.Data.ClrBindingWorker.NewValueAvailable(Boolean dependencySourcesChanged, Boolean initialValue, Boolean isASubPropertyChange)
   at MS.Internal.Data.PropertyPathWorker.UpdateSourceValueState(Int32 k, ICollectionView collectionView, Object newValue, Boolean isASubPropertyChange)
   at MS.Internal.Data.PropertyPathWorker.OnDependencyPropertyChanged(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange)
   at MS.Internal.Data.ClrBindingWorker.OnSourceInvalidation(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange)
   at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
   at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
   at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
   at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs)
   at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
   at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.ProcessPostedRecordsInViewChanged(Object param)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
   --- End of inner exception stack trace ---
