After upgrading to Infragistics 15.2, the drop down on xamMultiColumnComboEditor always displays on the left of the screen - see attached. Is this a known issue? Is there a workaround?
Arthur
Hello, Arthur,
Is it possible to provide the following information in order to investigate this problem further?
What is the specified handedness (right-handed or left-handed) in the Tablet PC Settings on the machine on which you use the xamMultiColumnComboEditor control?
In order to identify the specified handedness, open Control Panel and click on Tablet PC Settings. Click on the Other tab.
http://www.thewindowsclub.com/windows-surface-settings-left-handed
Sincerely,
Svetla
Infragistics, Inc.
www.infragistics.com/support
Right-handed. Note that I have tested on a few different Windows 8.1 computers and always get the same result.
I have logged this behavior in our tracking system with ID 209145 and the following case was created for you: CAS-166507-L9V6G2. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
Meanwhile, as a temporary workaround I can propose to set the XamMultiColumnComboEditor MinDropDownWidth property value to the control width.
I have attached a sample application.
Thanks! The workaround will do for now.
If you require any further assistance concerning this issue, please do not hesitate to ask.
