1770
NodeCheckedChanged executing when unregistered
What I need to happen:
1)I need a datatree whos checkboxes are mutually exclusive.
2)When I check a checkbox I need to manipulate other UI items based on the selection
3)I need to go back to the view model and update some properties based on the selection
This is what I have:
<ig:XamDataTree x:Name="LogsTree"
ItemsSource="{Binding LogItems}"
NodeCheckedChanged="LogsTree_OnNodeCheckedChanged">
<ig:XamDataTree.CheckBoxSettings>
<ig:CheckBoxSettings CheckBoxVisibility="Visible"/>
</ig:XamDataTree.CheckBoxSettings>
<ig:XamDataTree.SelectionSettings>
<ig:TreeSelectionSettings NodeSelection="Single"/>
</ig:XamDataTree.SelectionSettings>
<ig:XamDataTree.GlobalNodeLayouts>
<ig:NodeLayout Key="Logs" DisplayMemberPath="Text" CheckBoxMemberPath="IsChecked"/>
</ig:XamDataTree.GlobalNodeLayouts>
<i:Interaction.Triggers>
<i:EventTrigger EventName="NodeCheckedChanged" >
<command:EventToCommand Command="{Binding LogSelectionCommand}" PassEventArgsToCommand="True" />
</i:EventTrigger>
</i:Interaction.Triggers>
</ig:XamDataTree>
private void LogsTree_OnNodeCheckedChanged(object sender, NodeEventArgs e)
LogsTree.NodeCheckedChanged -= LogsTree_OnNodeCheckedChanged;
var index = e.Node.Index;
foreach (var node in LogsTree.Nodes)
node.IsChecked = false;
LogsTree.Nodes[index].IsChecked = true;
LogsTree.NodeCheckedChanged += LogsTree_OnNodeCheckedChanged;
private void LogSelectionChanged(object e)
//this is the method that executes in my view model when someone check something the LogTree
What happens is that even though I unregistered the NodeCheckedChanged event for LogTree, method LogSelectionChanged command still excutes in my view model because of this code:
I only want it to execute once. Is this possible?
  • 34510
    Verified Answer
    Hi Kris,
    You can remove the event trigger before the code executes and then re-apply it like you do with the LogsTree_OnNodeCheckedChanged handler.
    var triggers = System.Windows.Interactivity.Interaction.GetTriggers(LogsTree);
    var nodeCheckedTrigger = triggers[0];
    triggers.Remove(nodeCheckedTrigger);
    // do stuff
    triggers.Add(nodeCheckedTrigger);
