30
Adding buttons to rows in datagrid
Hi There,
I'm just starting out with WPF and would like to add buttons to each row in a xaml grid with each buttons event handler being able to tell which row the button was clicked on.  I haven't seen this in any of the samples.  Does anyone have any examples of this?
I could get the user to select the row and click one common button however the application must be very quick to use and having icons/buttons in the rows would cut the clicks necessary in half.
Thanks in advance,
Rob
  • 245
     I created a an unbound field and then styled/template the cellvaluepresenter.  hope this helps.
    <igDP:UnboundField>
                                    <igDP:Field.Settings>
                                        <igDP:FieldSettings CellMaxWidth="40" LabelMaxWidth="40" CellMinWidth="40" LabelMinWidth="40">
                                         <igDP:FieldSettings.CellValuePresenterStyle>
                                            <Style TargetType="{x:Type igDP:CellValuePresenter}">
                                                <Setter Property="Visibility" Value="Hidden" />
                                                <Setter Property="Template">
                                                    <Setter.Value>
                                                        <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                                                            <Grid Width="50">
        <Grid.ColumnDefinitions>
        <ColumnDefinition Width="20" />
        </Grid.ColumnDefinitions>
        <Button  Grid.Column="0" Width="15" Height="15"
        Command="cust:PopupControl.ShowCommand"
        CommandTarget="{Binding ElementName=ModifySrpCategoryPopup}"
        CommandParameter="{TemplateBinding Record, Converter={StaticResource DataRecordConverter}}"
        ToolTip="{g:LocalizedResource Name=ModifyCommand}"
        Style="{DynamicResource EditButtonStyle}"
        HorizontalAlignment="Center" />
        <Button  Grid.Column="1" Width="15" Height="15"
        Command="rmsClient:RmsCommands.Delete" HorizontalAlignment="Center" ToolTip="Delete"
        Style="{DynamicResource DeleteButton}"/>
        </Grid>
                                                        </ControlTemplate>
                                                    </Setter.Value>
                                                </Setter>
                                                    <Style.Triggers>
                                                        <DataTrigger Binding="{Binding IsSelected}" Value="True">
                                                            <Setter Property="Visibility" Value="Visible"/>
                                                        </DataTrigger>
                                                    </Style.Triggers>
                                               </Style>
                                            </igDP:FieldSettings.CellValuePresenterStyle>
                                        </igDP:FieldSettings>
                                   </igDP:Field.Settings>
                               </igDP:UnboundField>
