I want to have the scroll bars hidden when the zoom is the default (100%), but when the user zooms in I want the XamDataChart to show the scroll bars. I do not know if there is an event that I can use or if it is a default feature in this control.
Note, to make the interaction smoother, you could leave some padding around the chart when the zoom bars are not displayed, and remove the padding at the same time as showing the zoombars.
-Graham
Yes, you can use the ActualWindowRectChangedEvent:
https://gist.github.com/gmurray81/0be8af59bc93e515be70
public MainWindow() { InitializeComponent(); chart.ActualWindowRectChanged += chart_ActualWindowRectChanged; } void chart_ActualWindowRectChanged(object sender, Infragistics.RectChangedEventArgs e) { if (e.NewRect.Width < 1.0 || e.NewRect.Height < 1.0) { chart.HorizontalZoombarVisibility = System.Windows.Visibility.Visible; chart.VerticalZoombarVisibility = System.Windows.Visibility.Visible; } else { chart.HorizontalZoombarVisibility = System.Windows.Visibility.Collapsed; chart.VerticalZoombarVisibility = System.Windows.Visibility.Collapsed; } }
Hope this helps!
