450
How to ignore screen boundaries while dragging?
while dragging a control using the D/D Framework, the dragged control will visually stop at screen boundaries. Example from the samples browser on a multi-monitor setup:
If you drag further, it will "snap" over to the other screen, but it's not possible to have the image basically in between the two monitors.
I want to achieve something like this:
The issue here is that we have a drop target that is near one of the screen edges. If we drag a slightly larger image (say, 300x300px) on it, the cursor will move to the target (and the drag/drop operation succeeds), but the image will block on the screen boundaries. This might be slightly confusing to our users, and we would like to just ignore the edges. I haven't found anything about that in the docs, is this possible to do?
  • 54937
    I was wondering if you had a chance to download the latest SR and verify that the issue has been resolved?
  • 54937
    Technically the dragged element is hosted in a WPF popup and the WPF framework adjusts the position of the popups such that it is within a single monitor so this is expected behavior. That being said we may be able to work around the behavior so I've submitted an issue for this - TFS207349.
