5
App crashing using XamLinearGauge on a Uno app targeting WinUI for desktop
Repro steps:
- install uno dotnet templates (https://nuget.org/packages/Uno.ProjectTemplates.Dotnet/3.5.0-dev.105
- run "dotnet new unoapp-winui" to create new solution
- set winui package project as startup (I unloaded all the other head projects)
- add nuget ref to Infragistics.WinUI.Gauges library
- add XamLinearGauge to MainPage (inside the existing Grid)
- Run app and mouse over the gauge
Expected behaviour: app runs without crashing
Actual behaviour: app crashes when mouse moves over the XamLinearGauge control, or when the window is resized
Two work arounds:
- set the height on the XamLinearGauge
- another fix seems to be holding a class level reference to the window that's generated in the OnLaunching method in app.xaml.cs I wasn't able to get any useful exception (managed or native) so not sure exactly the cause.
