70
UltraGrid with related DataTables
 Hi guys, I need help urgently. I have two tables:
TableA, with columns ID, B_ID, Name and
TableB,  with columns ID, Description.
Tables  connected by DataRelation from TableA:B_ID to TableB:ID.
How I can tell UltraGrid to display Description value from TableB, instead B_ID, when binds to TableA? Grid is read-only.
  • 469350
    Verified Answer
     I'm not sure I understand your question. If you are asking how to hide a column, you use the Hidden property on the column. You would typically do this in the InitializeLayout event of the grid. Something like this:
    e.Layout.Bands["TableA_TableB"].Columns["ID"].Hidden = true;
    In the above line of code "TableA_TableB" refers to the key of the data relation.
