I am using an UltraDropDown control in conjunction with an UltraDateTimeEditor. I have filled the drop down with times from 12:00 AM to 11:45 PM and when the user drops it down I need it to select the appropriate row and scroll it to the top of the list. Currently I have successfully found the index of the row and selected it, but I can't figure out how to get that row to be scrolled to the top of the list. So far it always drops down starting at 12 AM and I have to scroll way down to find the row that is currently selected. Any suggestions?
An interesting issue you have there, here let me see if I can help. I think if you can find the UltraGridRow that needs to be selected (which it sounds like you do) you can call row.Activate() and then row.Selected = true. This should bring the row into view and select it. I hope this helps.
