I upgraded an application from 13.1 to 13.2. I can run in my development environment without a problem, but when i deploy to our testing environment, we get the nullreferenceexcption. Here is the stack trace:
System.NullReferenceException: Object reference not set to an instance of an object. at Infragistics.Win.UltraWinDock.UltraDockManager.InitializeFrom(UltraDockManager source) at Infragistics.Win.UltraWinDock.UltraDockManager.Load(Stream stream, Boolean xml) at Infragistics.Win.UltraWinDock.UltraDockManager.LoadFromXML(String filename) at DSI.ReportingStudio.VisualAnalysis.ReportsViewer.LoadReports(DataRow drReportsSubScribed, DataTable dtReports)
Here is the xml that is loaded:
<SOAP-ENV:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:clr="http://schemas.microsoft.com/soap/encoding/clr/1.0" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><a1:UltraDockManager xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-1"><ControlPanes href="#ref-3" /><DefaultPaneSettings href="#ref-4" /><DockAreas href="#ref-5" /><ShowDisabledButtons>false</ShowDisabledButtons><WindowStyle>6</WindowStyle></a1:UltraDockManager><a1:DockableControlPanesCollection xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-3"><Count>10</Count></a1:DockableControlPanesCollection><a1:PaneSettings xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-4"><ActiveCaptionAppearance href="#ref-7" /><ActivePaneAppearance href="#ref-8" /><CaptionAppearance href="#ref-9" /><ActiveSlidingGroupAppearance href="#ref-10" /></a1:PaneSettings><a1:DockAreasCollection xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-5"><Count>8</Count><_x0030_ href="#ref-11" /><_x0031_ href="#ref-12" /><_x0032_ href="#ref-13" /><_x0033_ href="#ref-14" /><_x0034_ href="#ref-15" /><_x0035_ href="#ref-16" /><_x0036_ href="#ref-17" /><_x0037_ href="#ref-18" /></a1:DockAreasCollection><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-7"><Appearance href="#ref-19" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-8"><Appearance href="#ref-20" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-9"><Appearance href="#ref-21" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-10"><Appearance href="#ref-22" /></a2:AppearanceHolder><a1:DockAreaPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-11"><Text id="ref-25">25M Revise cd</Text><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue id="ref-26" xsi:type="SOAP-ENC:string">54932</objectValue></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>1108</width><height>52</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-1023031267</_a><_b>-10011</_b><_c>19512</_c><_d>128</_d><_e>150</_e><_f>88</_f><_g>152</_g><_h>20</_h><_i>35</_i><_j>246</_j><_k>25</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><Panes href="#ref-27" /><DefaultPaneSettings href="#ref-28" /><SelectedTabIndex>0</SelectedTabIndex></a1:DockAreaPane><a1:DockAreaPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-12"><Text id="ref-29">Agg balance report</Text><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue id="ref-30" xsi:type="SOAP-ENC:string">53103</objectValue></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>1108</width><height>52</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-583358852</_a><_b>-17549</_b><_c>19550</_c><_d>164</_d><_e>76</_e><_f>21</_f><_g>18</_g><_h>245</_h><_i>79</_i><_j>139</_j><_k>112</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><Panes href="#ref-31" /><DefaultPaneSettings href="#ref-32" /><SelectedTabIndex>0</SelectedTabIndex></a1:DockAreaPane><a1:DockAreaPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-13"><Text id="ref-33">DDA New Summary Report</Text><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue id="ref-34" xsi:type="SOAP-ENC:string">3820</objectValue></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>1108</width><height>52</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-857503705</_a><_b>-30737</_b><_c>19428</_c><_d>160</_d><_e>173</_e><_f>2</_f><_g>84</_g><_h>25</_h><_i>56</_i><_j>1</_j><_k>91</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><Panes href="#ref-35" /><DefaultPaneSettings href="#ref-36" /><SelectedTabIndex>0</SelectedTabIndex></a1:DockAreaPane><a1:DockAreaPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-14"><Text id="ref-37">DDA RMS Shift Click 08162013</Text><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue id="ref-38" xsi:type="SOAP-ENC:string">56293</objectValue></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>1108</width><height>52</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>1680967333</_a><_b>-27803</_b><_c>16791</_c><_d>144</_d><_e>70</_e><_f>101</_f><_g>175</_g><_h>10</_h><_i>179</_i><_j>206</_j><_k>85</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><Panes href="#ref-39" /><DefaultPaneSettings href="#ref-40" /><SelectedTabIndex>0</SelectedTabIndex></a1:DockAreaPane><a1:DockAreaPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-15"><Text id="ref-41">FMS xlxs over 65K test 05282014</Text><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue id="ref-42" xsi:type="SOAP-ENC:string">90407</objectValue></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>1108</width><height>52</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>1437672720</_a><_b>23291</_b><_c>17060</_c><_d>148</_d><_e>248</_e><_f>136</_f><_g>70</_g><_h>155</_h><_i>152</_i><_j>100</_j><_k>217</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><Panes href="#ref-43" /><DefaultPaneSettings href="#ref-44" /><SelectedTabIndex>0</SelectedTabIndex></a1:DockAreaPane><a1:DockAreaPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-16"><Text id="ref-45">Arrange calc fields</Text><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue id="ref-46" xsi:type="SOAP-ENC:string">52964</objectValue></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>1108</width><height>52</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>953219929</_a><_b>10542</_b><_c>19689</_c><_d>181</_d><_e>189</_e><_f>235</_f><_g>70</_g><_h>15</_h><_i>159</_i><_j>21</_j><_k>149</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><Panes href="#ref-47" /><DefaultPaneSettings href="#ref-48" /><SelectedTabIndex>0</SelectedTabIndex></a1:DockAreaPane><a1:DockAreaPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-17"><Text id="ref-49">A simple</Text><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue id="ref-50" xsi:type="SOAP-ENC:string">4089</objectValue></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>1108</width><height>52</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-20581219</_a><_b>-16142</_b><_c>17767</_c><_d>149</_d><_e>81</_e><_f>162</_f><_g>97</_g><_h>106</_h><_i>211</_i><_j>191</_j><_k>173</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><Panes href="#ref-51" /><DefaultPaneSettings href="#ref-52" /><SelectedTabIndex>0</SelectedTabIndex></a1:DockAreaPane><a1:DockAreaPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-18"><Text id="ref-53">Group Criteria Aggregate report clb</Text><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue id="ref-54" xsi:type="SOAP-ENC:string">103983</objectValue></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>1108</width><height>52</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-1037746723</_a><_b>-7357</_b><_c>16663</_c><_d>131</_d><_e>176</_e><_f>159</_f><_g>167</_g><_h>196</_h><_i>133</_i><_j>196</_j><_k>171</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><Panes href="#ref-55" /><DefaultPaneSettings href="#ref-56" /><SelectedTabIndex>0</SelectedTabIndex></a1:DockAreaPane><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-19"><BackColor xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Color"><name xsi:null="1" /><value>0</value><knownColor>164</knownColor><state>1</state></BackColor><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-20"><BackColor xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Color"><name xsi:null="1" /><value>0</value><knownColor>164</knownColor><state>1</state></BackColor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-21"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">1</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-22"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">1</objectValue></Cursor><Id>0</Id></a2:Appearance><a1:DockablePanesCollection xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-27"><Count>1</Count><_x0030_ href="#ref-57" /></a1:DockablePanesCollection><a1:PaneSettings xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-28"><ActiveCaptionAppearance href="#ref-58" /><ActivePaneAppearance href="#ref-59" /></a1:PaneSettings><a1:DockablePanesCollection xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-31"><Count>1</Count><_x0030_ href="#ref-60" /></a1:DockablePanesCollection><a1:PaneSettings xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-32"><ActiveCaptionAppearance href="#ref-61" /><ActivePaneAppearance href="#ref-62" /></a1:PaneSettings><a1:DockablePanesCollection xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-35"><Count>1</Count><_x0030_ href="#ref-63" /></a1:DockablePanesCollection><a1:PaneSettings xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-36"><ActiveCaptionAppearance href="#ref-64" /><ActivePaneAppearance href="#ref-65" /></a1:PaneSettings><a1:DockablePanesCollection xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-39"><Count>1</Count><_x0030_ href="#ref-66" /></a1:DockablePanesCollection><a1:PaneSettings xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-40"><ActiveCaptionAppearance href="#ref-67" /><ActivePaneAppearance href="#ref-68" /></a1:PaneSettings><a1:DockablePanesCollection xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-43"><Count>1</Count><_x0030_ href="#ref-69" /></a1:DockablePanesCollection><a1:PaneSettings xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-44"><ActiveCaptionAppearance href="#ref-70" /><ActivePaneAppearance href="#ref-71" /></a1:PaneSettings><a1:DockablePanesCollection xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-47"><Count>1</Count><_x0030_ href="#ref-72" /></a1:DockablePanesCollection><a1:PaneSettings xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-48"><ActiveCaptionAppearance href="#ref-73" /><ActivePaneAppearance href="#ref-74" /></a1:PaneSettings><a1:DockablePanesCollection xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-51"><Count>1</Count><_x0030_ href="#ref-75" /></a1:DockablePanesCollection><a1:PaneSettings xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-52"><ActiveCaptionAppearance href="#ref-76" /><ActivePaneAppearance href="#ref-77" /></a1:PaneSettings><a1:DockablePanesCollection xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-55"><Count>1</Count><_x0030_ href="#ref-78" /></a1:DockablePanesCollection><a1:PaneSettings xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-56"><ActiveCaptionAppearance href="#ref-79" /><ActivePaneAppearance href="#ref-80" /></a1:PaneSettings><a1:DockableControlPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-57"><Text href="#ref-25" /><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue href="#ref-26" /></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>0</width><height>0</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-1697916526</_a><_b>-649</_b><_c>18011</_c><_d>164</_d><_e>3</_e><_f>40</_f><_g>185</_g><_h>63</_h><_i>31</_i><_j>3</_j><_k>228</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-1023031267</_a><_b>-10011</_b><_c>19512</_c><_d>128</_d><_e>150</_e><_f>88</_f><_g>152</_g><_h>20</_h><_i>35</_i><_j>246</_j><_k>25</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><ControlName id="ref-81">54932ReportName</ControlName><OriginalControlBounds xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Rectangle"><x>0</x><y>0</y><width>819</width><height>606</height></OriginalControlBounds><ControlPaneIndex>0</ControlPaneIndex></a1:DockableControlPane><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-58"><Appearance href="#ref-82" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-59"><Appearance href="#ref-83" /></a2:AppearanceHolder><a1:DockableControlPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-60"><Text href="#ref-29" /><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue href="#ref-30" /></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>0</width><height>0</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>577178258</_a><_b>-5669</_b><_c>16501</_c><_d>149</_d><_e>45</_e><_f>95</_f><_g>200</_g><_h>225</_h><_i>2</_i><_j>154</_j><_k>112</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-583358852</_a><_b>-17549</_b><_c>19550</_c><_d>164</_d><_e>76</_e><_f>21</_f><_g>18</_g><_h>245</_h><_i>79</_i><_j>139</_j><_k>112</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><ControlName id="ref-84">53103ReportName</ControlName><OriginalControlBounds xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Rectangle"><x>0</x><y>0</y><width>819</width><height>606</height></OriginalControlBounds><ControlPaneIndex>1</ControlPaneIndex></a1:DockableControlPane><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-61"><Appearance href="#ref-85" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-62"><Appearance href="#ref-86" /></a2:AppearanceHolder><a1:DockableControlPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-63"><Text href="#ref-33" /><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue href="#ref-34" /></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>0</width><height>0</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-1972183929</_a><_b>14428</_b><_c>17752</_c><_d>158</_d><_e>199</_e><_f>221</_f><_g>157</_g><_h>159</_h><_i>127</_i><_j>239</_j><_k>218</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-857503705</_a><_b>-30737</_b><_c>19428</_c><_d>160</_d><_e>173</_e><_f>2</_f><_g>84</_g><_h>25</_h><_i>56</_i><_j>1</_j><_k>91</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><ControlName id="ref-87">3820ReportName</ControlName><OriginalControlBounds xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Rectangle"><x>0</x><y>0</y><width>819</width><height>606</height></OriginalControlBounds><ControlPaneIndex>2</ControlPaneIndex></a1:DockableControlPane><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-64"><Appearance href="#ref-88" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-65"><Appearance href="#ref-89" /></a2:AppearanceHolder><a1:DockableControlPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-66"><Text href="#ref-37" /><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue href="#ref-38" /></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>0</width><height>0</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>65906702</_a><_b>5360</_b><_c>19203</_c><_d>171</_d><_e>172</_e><_f>181</_f><_g>63</_g><_h>230</_h><_i>182</_i><_j>145</_j><_k>198</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>1680967333</_a><_b>-27803</_b><_c>16791</_c><_d>144</_d><_e>70</_e><_f>101</_f><_g>175</_g><_h>10</_h><_i>179</_i><_j>206</_j><_k>85</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><ControlName id="ref-90">56293ReportName</ControlName><OriginalControlBounds xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Rectangle"><x>0</x><y>0</y><width>819</width><height>606</height></OriginalControlBounds><ControlPaneIndex>3</ControlPaneIndex></a1:DockableControlPane><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-67"><Appearance href="#ref-91" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-68"><Appearance href="#ref-92" /></a2:AppearanceHolder><a1:DockableControlPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-69"><Text href="#ref-41" /><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue href="#ref-42" /></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>0</width><height>0</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-1551354080</_a><_b>-20156</_b><_c>17299</_c><_d>166</_d><_e>163</_e><_f>6</_f><_g>240</_g><_h>42</_h><_i>98</_i><_j>209</_j><_k>121</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>1437672720</_a><_b>23291</_b><_c>17060</_c><_d>148</_d><_e>248</_e><_f>136</_f><_g>70</_g><_h>155</_h><_i>152</_i><_j>100</_j><_k>217</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><ControlName id="ref-93">90407ReportName</ControlName><OriginalControlBounds xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Rectangle"><x>0</x><y>0</y><width>819</width><height>606</height></OriginalControlBounds><ControlPaneIndex>4</ControlPaneIndex></a1:DockableControlPane><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-70"><Appearance href="#ref-94" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-71"><Appearance href="#ref-95" /></a2:AppearanceHolder><a1:DockableControlPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-72"><Text href="#ref-45" /><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue href="#ref-46" /></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>0</width><height>0</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>771921698</_a><_b>-21083</_b><_c>16594</_c><_d>171</_d><_e>236</_e><_f>48</_f><_g>223</_g><_h>175</_h><_i>188</_i><_j>59</_j><_k>168</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>953219929</_a><_b>10542</_b><_c>19689</_c><_d>181</_d><_e>189</_e><_f>235</_f><_g>70</_g><_h>15</_h><_i>159</_i><_j>21</_j><_k>149</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><ControlName id="ref-96">52964ReportName</ControlName><OriginalControlBounds xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Rectangle"><x>0</x><y>0</y><width>819</width><height>606</height></OriginalControlBounds><ControlPaneIndex>5</ControlPaneIndex></a1:DockableControlPane><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-73"><Appearance href="#ref-97" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-74"><Appearance href="#ref-98" /></a2:AppearanceHolder><a1:DockableControlPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-75"><Text href="#ref-49" /><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue href="#ref-50" /></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>0</width><height>0</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-490556272</_a><_b>-5534</_b><_c>17053</_c><_d>133</_d><_e>0</_e><_f>101</_f><_g>143</_g><_h>120</_h><_i>112</_i><_j>70</_j><_k>171</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-20581219</_a><_b>-16142</_b><_c>17767</_c><_d>149</_d><_e>81</_e><_f>162</_f><_g>97</_g><_h>106</_h><_i>211</_i><_j>191</_j><_k>173</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><ControlName id="ref-99">4089ReportName</ControlName><OriginalControlBounds xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Rectangle"><x>0</x><y>0</y><width>819</width><height>606</height></OriginalControlBounds><ControlPaneIndex>6</ControlPaneIndex></a1:DockableControlPane><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-76"><Appearance href="#ref-100" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-77"><Appearance href="#ref-101" /></a2:AppearanceHolder><a1:DockableControlPane xmlns:a1="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win.UltraWinDock/Infragistics4.Win.UltraWinDock.v13.2" id="ref-78"><Text href="#ref-53" /><Tag xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:ObjectWrapper"><objectValue href="#ref-54" /></Tag><Size xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Size"><width>0</width><height>0</height></Size><Id xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>2006750379</_a><_b>-20449</_b><_c>18156</_c><_d>188</_d><_e>89</_e><_f>251</_f><_g>36</_g><_h>166</_h><_i>6</_i><_j>74</_j><_k>146</_k></Id><DockedParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>-1037746723</_a><_b>-7357</_b><_c>16663</_c><_d>131</_d><_e>176</_e><_f>159</_f><_g>167</_g><_h>196</_h><_i>133</_i><_j>196</_j><_k>171</_k></DockedParentId><FloatingParentId xmlns:a5="http://schemas.microsoft.com/clr/ns/System" xsi:type="a5:Guid"><_a>0</_a><_b>0</_b><_c>0</_c><_d>0</_d><_e>0</_e><_f>0</_f><_g>0</_g><_h>0</_h><_i>0</_i><_j>0</_j><_k>0</_k></FloatingParentId><ControlName id="ref-102">103983ReportName</ControlName><OriginalControlBounds xmlns:a4="http://schemas.microsoft.com/clr/nsassem/System.Drawing/System.Drawing" xsi:type="a4:Rectangle"><x>0</x><y>0</y><width>819</width><height>606</height></OriginalControlBounds><ControlPaneIndex>8</ControlPaneIndex></a1:DockableControlPane><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-79"><Appearance href="#ref-103" /></a2:AppearanceHolder><a2:AppearanceHolder xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-80"><Appearance href="#ref-104" /></a2:AppearanceHolder><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-82"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-83"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-85"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-86"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-88"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-89"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-91"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-92"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-94"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-95"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-97"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-98"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-100"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-101"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-103"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance><a2:Appearance xmlns:a2="http://schemas.microsoft.com/clr/nsassem/Infragistics.Win/Infragistics4.Win.v13.2" id="ref-104"><Cursor xmlns:a3="http://schemas.microsoft.com/clr/nsassem/Infragistics.Shared.Serialization/Infragistics4.Shared.v13.2" xsi:type="a3:CursorWrapper"><objectValue xsi:type="xsd:int">9</objectValue></Cursor><Id>0</Id></a2:Appearance></SOAP-ENV:Body></SOAP-ENV:Envelope>
Anyone have any ideas what would cause this error?
Currie
I was not able to reproduce this bug with the latest 13.2 source, so my first guess would be this is a bug that has been fixed since the original 13.2 release, and you downloaded the 13.2 volume release. 13.2 is no longer supported and I can't remember if they make those older builds available to customers, but if they do, I would try that first. If you still get the exception, attach your sample project source and we'll try to reproduce the bug with that.
Brian,
I am running 13.2.20132.2098. That seems to be the same version available for download.
Unfortunately i am unable to reproduce the problem in my environment. It only happens at my customer's test site. Is it possible you can evaluate the xml and see if there is something that could cause such an error?
I'm not sure what you mean by "evaluate" the XML. There is far too much of it to scan with the naked eye, and if the LoadFromXml method successfully loads it, we can be certain that the XML is well-formed, and also that it does not contain any corrupted data, otherwise an exception would have been thrown.
Please let us know if you need any more help with this, otherwise we'll close the case...thanks.
