I have a varchar column with both numerics and alphabets so when i am using the header click to sort them they are sorting based on ASCII values
like
1
11
2
3
can i manipulate it so that i can get the data like
Hello Ven Ram,
UltraGrid’s column exposes SortComparer property. You may use this property for custom sort comparison when sorting rows in a column. More about this property you may find by following the next link http://help.infragistics.com/Help/Doc/WinForms/2015.1/CLR4.0/html/Infragistics4.Win.UltraWinGrid.v15.1~Infragistics.Win.UltraWinGrid.UltraGridColumn~SortComparer.html.
Please check also the following forum thread where similar question were discussed http://es.infragistics.com/community/forums/t/60457.aspx.
Please let me know if you have any additional questions.
