In my test application I try to resize a pane by setting the panes Size property. Attached is my source code to illustrate my problem. What I am trying to do is to be able to shrink or grow the width of a panel(pane) as needed. I need this functionality. I am using 13.1 controls.
To resize I tried this when the user clicks a button it:
_leftPanelWidth += 100;
var myPane = ultraDockManager1.DockAreas[0].Panes[0];
myPane.Size = new Size(_leftPanelWidth, myPane.Size.Height);
But the panes stay in the same spot.
What am I doing wrong?
This is the expected behavior. The UltraDockManager behaves like standard docking behaviors in .NET (and was designed to work like Visual Studio).
When you dock a control to the top/bottom, the width of the control is equivalent to the width of it's container, and similarly, docking a control to the left/right will cause the height of the control to be set to the height of its container.
Chris
I'm using the following code:
DockableControlPane controlPane = new DockableControlPane("statistics", "Area filtering and statistics", dockedControl);controlPane.FlyoutSize = new Size(200, 200);controlPane.Size = new Size(200, 200);controlPane.MaximumSize = new Size(200, 200);
DockAreaPane dockArea = new DockAreaPane(DockedLocation.DockedBottom);dockArea.Panes.Add(controlPane);dockArea.ChildPaneStyle = ChildPaneStyle.TabGroup;dockArea.Size = new Size(200, 200);dockArea.GroupSettings.TabSizing = Infragistics.Win.UltraWinTabs.TabSizing.AutoSize;dockArea.MaximumSize = new Size(200, 200);dockArea.Unpin();
DockManager.DockAreas.AddRange(new DockAreaPane[] { dockArea });
But for some reason the pane's width is the same as the container's. Does anybody have any suggestions for why this is happening?
Hello.
Depending on where the control is docked, the Height/Width of the pane is based on the owning DockAreaPane. As such, you need to set the height/width on the owning DockArea which can be accessed via the DockAreas collection on the UltraDockManager, or the DockAreaPane property on the specific DockableControlPane.
Let me know if you have any further questions.
