In my application v1, I displayed data about appoitnements in a grid as a minutes value (integer)
My customer has me to display it and let it be modifiable as hh:mm
I don't find how to achieve that ?
Any though ?
Hello Yannick,
I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
Thank you for posting in our forums.
What you could do in your case is to add an unbound DateTime column and hide your integer one. Then in the InitializeRow you will calculate the value of the DateTime column based on the value of the Integer column the first time the row is initialized and then vice-versa the next time the row is re-initialized.
I have attached a sample demonstrating this approach.
Please let me know if you have any additional questions.
