1040
GridBagLayoutManger ContainerControl.
I added UltraPanel & UltraGridBagLayoutManager.
And I changed name of UltraPanel(myPanel).
And then Change myPanel added to ContainerContorl.
But containercontrol is not apply.
Containercontrol -> None...
  • 23930
    Thank you for posting in our forums.
    I was able to reproduce this issue on my machine so I logged it in our internal issue tracking system with ID of 202526. I also opened a private case for you (CAS-158156-S0F3Q6) so that you will be notified as soon as the issue is fixed. You can find your currently active cases from this link:
    https://es.infragistics.com/my-account/support-activity
    As a workaround, after you set the ControlContainer to the UltraPanel (it will still appear that the ControlContainer is “None”) restart VisualStudio. Then the ControlContainer will be properly set to the UltraPanel.
