I posted the same question in the ASP.NET forum by mistake ... it belongs in the Windows Forms forum. By the time I figured out that it was in the wrong one I could not delete it so sorry about that.
I'm sure I'm just missing it but is there a way to add a comment to an excel cell? I see "Hascomment" and ClearComment type properties/methods but no Add?
Computer monitor can support thousands of displays. If the screen resolution is changed in any system, it will be effective for all the users using the machine
Those properties/methods were added to allow someone to remove a comment and determine if a cell has a comment, but we currently do not support the ability to create and modify existing comments. However, this feature should eventually be added and submitting a feature request to the support group will likely increase the chances this is implemented in an upcomming release: http://devcenter.infragistics.com/Protected/SubmitSupportIssue.Aspx.
