95
How do I set a default value in an ultracombobox
hi,
I've been trying to figure out how to set a default value in an ultracombobox, when its dropdownstyle is dropdownlist.  When I change the dropdownstyle to dropdown, I can set the default value by using ultracombobox.Text = "Text", and it works fine, but when I try the same thing when the dropdownstyle is dropdownlist, the default value does not show.
 The reason I want to use dropdownlist, and not dropdown, is because dropdownlist does not allow the user to type anything into the combobox, while dropdown does.
- Chad
  • 280
     Hello Chad,
    You need to set the  ultracombobox.Value = null;
    the UltraCombo works with ValueMember and DisplayMember, is always better to set the .Value property.
    Nassos
