Hi Team,
I have linked to events "Mouse Click", few lines of business code in an application (regarding the button clicked and the selected items, I can then display a popup menu if right click is used for example)
My problem is that when using the scrolling bar, the same event is fired and I have no way to tell the system that this is a scrolling event so all the business logic is triggered again and it is very time cost effective !
Is there a better way to handdle that ?
Hello Yannick,
I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
Hi Yannick,
Thank you for positing in our forums.
What you could do is to check which UIElement was click before executing your business logic. You can do that by using the ElementFromPoint method of the UltraTimeLineView.UIElement. Then you can use the GetContext method of the clicked UIElement and see if it has a context of type ScrollBarInfo. If it has then the user is scrolling and you shouldn’t do anything. Otherwise you can be sure that the user hasn’t clicked the scrollbar and you can execute your business logic.
I have attached a sample in order to demonstrate this suggestion.
Please let me know if you have any additional questions.
