705
how to set initial value but not add to items in a dropdownlist
In a comboEditor, I need to set the drowpdownstyle to "drowdownlist", and set the initial text like "please select ..." ( I don't want to add this to the comboEditor's items), then how can I do?
Thank you very much
Wei
  • 469350
    Hi Wei,
    In DropDownList style, the combo's value has to match an item on the list. If you set Nulable to true, it should accept null, though. So what you probably need to do is set Nullable to true, default the value of the control to null or DBNull.Value and then set the NullTextLabel to the text you want displayed.
