I am trying to track the event when the form is maximized. which event it is ?
The second problem is my slpitcontainer when you maximize it does not resize it only remains in its initial position. how do you make it become interactive ?
I was not able to make use of the designer file because there are quite a few event declarations which refer to methods that are implemented in a different file.
Attached is the designer, the problem is when I maximize the window the split between the ugridpupEvent grid and Rtestat , Optstats grids, do not move to the right to allow the ugridpupEvent grid to show all the table. Instead it remains in the same place whether I maximize or normal size load form.
Screen shots will probably not help at all. Designer code might help. A sample project which conclusively demonstrates the issue will help most and is the fastest way to get a solution to your problem.
Can screen shots be enough for you. or you want the designer file ?
If you provide us with a sample that demonstrates the problem we will be able to determine very quickly what you need to do to fix it.
