490
How to Disable the UltraNumericEditor without disabling the StateEditorButton inside
I've got a check box, a StateEditorButton, inside an UltraNumericEditor. The idea is to block input to the UltraNumericEditor when the checkbox is checked out.
I do that with the AfterCheckStateChanged event.
The problem is when I disable the UltraNumericEditor, the StateEditorButton gets also disabled. In that case, the user can't enable it again by checking in the checkbox.
What's the best solution to this scenario?
Shall I remove the StateEditorButton from the buttons collection of the UltraNumericEditor and implement it independently?
