Hi all!
Is there a way to Close the File-mneu on the ribbon per code?
That's it, Thank you!
Thank you for posting in our forums.
The Ribbon application menus have a CloseUp method, which will close the application menu if it is open. Depending on what style of the application menu you use, you should use either:
ultraToolbarsManager1.Ribbon.ApplicationMenu.CloseUp();
or
ultraToolbarsManager1.Ribbon.ApplicationMenu2010.CloseUp();
Please let me know if you have any additional questions.
