Using the ultraGrid to create a hierarchal tree, we are running into an error. Under uncertain conditions the display when expanding a level, the display blows up with the following error:
Anybody have a suggestion on what is happening here: The object does exist. but we are fetching the data at each expansion so it could be a timing issue.
Object reference not set to an instance of an object. (Infragistics2.Win.UltraWinGrid.v7.1)
------------------------------Program Location:
at Infragistics.Win.UltraWinGrid.UltraGridColumn.GetCachedCellAppearance(Boolean selected, AppearanceData& appData, ResolveAppearanceContext& context) at Infragistics.Win.UltraWinGrid.UltraGridRow.ResolveCellAppearance(UltraGridColumn column, AppearanceData& appData, AppearancePropFlags& requestedProps, Boolean cellAppearanceOnly, Boolean forceSelected, ForceActive forceActive, Boolean isMergedCell, Boolean hotTrackingCell, Boolean hotTrackingRow) at Infragistics.Win.UltraWinGrid.UltraGridLayout.ResolvedCachedCellAppearance(UltraGridRow row, UltraGridColumn column, AppearanceData& appData, AppearancePropFlags& flags, Boolean hotTrackingCell, Boolean hotTrackingRow) at Infragistics.Win.UltraWinGrid.CellUIElementBase.InternalInitAppearance(AppearanceData& appearance, AppearancePropFlags& requestedProps) at Infragistics.Win.UltraWinGrid.CellUIElementBase.InitAppearance(AppearanceData& appearance, AppearancePropFlags& requestedProps) at Infragistics.Win.UIElement.InitializeDrawAppearance(AppearanceData& defaultAppearance, AppearanceData& appearance) at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams) at Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams) at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams) at Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams) at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams) at Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams) at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams) at Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams) at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams) at Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams) at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams) at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics) at Infragistics.Win.UIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics) at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics) at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize) at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode) at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode) at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe) at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I will be happy to assist you with this issue.
Without knowing the certain circumstances you mentioned in your post, I won't be able to isolate the cause of this issue. If possible, please provide me with the steps you take to reproduce this issue and a sample application. This will allow me to better isolate the reason why this issue occurs and provide you with a solution. Also, I recommend that you download the latest service release whenever receiving errors using our controls.
Please download the latest Service Release using the instructions posted on this forum:http://community.infragistics.com/forums/t/29398.aspx
Please let me know if you have further questions regarding this matter.
