900
How to Display whole numbers on the Y-Axis
I have an UltraChart 8.1 in my app.  It is set to be a stacked bar chart.  I want the y axis to always show whole numbers (0, 1, 2), but it is splitting the y axis into tickmarks of it's own choosing (0, 0.4, 0.8, 1.2, 1.6, 2).  I saw a post that said I could set the format of the tickmark by setting chart.Axis.Y.Labels.ItemFormatString, but that does not change the intervals, so I ended up with a graph that was marked with rounded intervals (0, 1, 1, 2, 2).  I see that I can set chart.Axis.Y.TickmarkInterval to some number to specify the intervals, but that is not the perfect solution either.  I don't know how large my Y-axis should get - sometimes it may only need to go to 2, other times it could need to go to 100.  It would be nice if I could make it figure out intervals to display automatically, but make sure that they were whole-number intervals.  Is there a way to do that?
~Karen
