1179
Drawing control over ultragrid
With a control inheriting from an ultragrid I'd like to place another control on the design surface and have it draw itself over the ultragrid. When I try this though, the control isn't visible. Checking its properties I can see that it is visible, has a sensible, non-zero size, and a location that should be visible. I've also tried calling its BringToFront method. Is there any way I can do this?
We're trying to add functionality to all our grids (which use a class inheriting from the ultragrid) to be able to display an indicator that data is being fetched, along with a cancel button to abort the fetch. I've created a usercontrol to implement this, but am getting the behaviour described. I've tried using a simple standard control as well, but that isn't displayed either
