is it possible to show the week of year e.g. on the left side of the date dropdown?
Maybe like in Outlook - please see the screenshot.
Thank you,
best regards
Hello Milko,
thank you for your answer.
I wondered why the week number was e.g. correct in Outlook 2010, but then realized it uses a region independent setting "first 4-day week" which is set in Outlook options.
So because it is hardly possible to get an answer from Microsoft regarding this issue, I will have to use Germany instead of Austria setting.
Thank you for your help.
Hello Daniel,
Thank you for your feedback.
Yes, you are correct. However, we are using MS MonthCalendar in the drop down. So this is how Microsoft control calculates the first week of the year. Please, note the first week of the year is culture specific, so this is expected behavior. It could be the week where 1st of January is, it could be First 4-day week or First full week.
Please let me know if you need any further assistance.
sorry for replying on the old thread, but I have seen a little issue here regarding Windows region settings in combination e.g. with control UltraCalendarCombo.
In Windows 7 or 8.1, when I set Region Format to "German (Germany)" in system control, the week number from 28.12.2015 is 53 and from 04.01.2016 it is 1, which is correct.
When I change system Region Format to "German (Austria)", UltraCalendarCombo shows week number 1 from 28.12.2015, which is wrong.
The right setting for our region is "German (Austria)", or in German: "Deutsch (Österreich)". I would like to keep this setting and correct the error/bug in the software itself, rather than having every machine's setting changed to Germany.
Please give me some information how to solve this.
Thank you
Thank you!
It is not necessary to initialize a new instance of DateTimeEditor for each DateTime column in your grid. Actually it is best practice to initialize one instance and set it to each DateTime column, as long as you need same behavior in all DateTime columns.
Please check attached my revised sample solution implementing UltraGrid with three DateTime columns. With this approach you can add as much as you need DateTime columns and each one will have the same instance of DateTimeEditor.
