Need to be able to select a wingrid column and resize it. Then Assert on the resized column. On playback, the test selects the column and moves it rather than resizing. Any suggestions?
Thank you for your responses....I have yet to be able to assert on resized columns, but I have been able to move a column and assert that it has been moved to the new location. I'm also now trying to assert on some of the pined columns and assert that they have been pinned. Any suggestions there? Thanks in advance
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
You could record your DragHeader test and then you should modify it a little, on the following links are listed known issues and explanation of how to fix them regarding Codded UI Automation.
http://help.infragistics.com/Doc/WinForms/Current/CLR4.0/?page=Win_Known_Issues_in_2012_Volume_2.html
http://help.infragistics.com/Doc/WinForms/Current/CLR4.0/?page=Win_Known_Issues_in_2013_Volume_1.html
