150
Multiline image not sizing properly
I have a grid where I created an unbound column for Formatted text and made it multiline.  Each row is at least 2 lines in heigh but I added another column that is an image and when I put an image in it shrinks it dow so it woudl fit if the row was not multi line height.  Is there any way to get this to size properly.  The only way to seem to get a bigger image I have found is to set the background image property and set the style ot stretched but I would rather have the image be its normal size so there is a little border around it in the cell.
grdResults.DisplayLayout.Bands(0).Columns.Add("MatchTypeIcon")
grdResults.DisplayLayout.Bands(0).Columns("MatchTypeIcon").Header.Caption = ""
grdResults.DisplayLayout.Bands(0).Columns("MatchTypeIcon").Header.VisiblePosition = 2
grdResults.DisplayLayout.Bands(0).Columns("MatchTypeIcon").Header.Appearance.ImageHAlign = HAlign.Center
grdResults.DisplayLayout.Bands(0).Columns("MatchTypeIcon").Header.Appearance.ImageVAlign = VAlign.Middle
grdResults.DisplayLayout.Bands(0).Columns("MatchTypeIcon").DataType = GetType(System.Drawing.Bitmap)
grdResults.DisplayLayout.Bands(0).Columns("MatchTypeIcon").Style = Infragistics.Win.UltraWinGrid.ColumnStyle.Image
Private Sub grdResults_InitializeLayout(ByVal sender As System.Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs) Handles grdResults.InitializeLayout
grdResults.UseAppStyling = False
grdResults.UseOsThemes = DefaultableBoolean.False
grdResults.DisplayLayout.Override.ActiveRowAppearance.BackColor = Color.White
grdResults.DisplayLayout.Override.ActiveRowAppearance.ForeColor = Color.Black
grdResults.DisplayLayout.Override.ActiveRowAppearance.BorderColor = Color.Black
grdResults.DisplayLayout.Override.ActiveRowAppearance.BorderAlpha = Alpha.Opaque
grdResults.DisplayLayout.Override.HeaderAppearance.BackColor = Color.Transparent 'FromArgb(210, 226, 223)
grdResults.DisplayLayout.Override.HeaderAppearance.BackGradientStyle = GradientStyle.None
grdResults.DisplayLayout.Override.HeaderAppearance.BorderAlpha = Alpha.Opaque
grdResults.DisplayLayout.Override.BorderStyleCell = UIElementBorderStyle.None
grdResults.DisplayLayout.Override.RowAppearance.BorderColor = Color.Teal
grdResults.DisplayLayout.Appearance.BackColor = Color.Transparent
grdResults.DisplayLayout.Appearance.BorderAlpha = Alpha.Transparent
grdResults.DisplayLayout.Override.RowAppearance.BackColor = Color.Transparent
grdResults.DisplayLayout.Override.DefaultRowHeight = 40
grdResults.DisplayLayout.ViewStyleBand = ViewStyleBand.Vertical
grdResults.DisplayLayout.Bands(0).ColHeadersVisible = False
grdResults.DisplayLayout.Override.CellAppearance.TextVAlign = VAlign.Middle
grdResults.DisplayLayout.Override.RowSizing = RowSizing.AutoFixed
'e.Layout.AutoFitStyle = AutoFitStyle.ExtendLastColumn
For Each ugc As UltraGridColumn In grdResults.DisplayLayout.Bands(0).Columns
If ugc.Key <> "DisplayMatch" And ugc.Key <> "MatchTypeIcon" And ugc.Key <> "DisplayMatchNumber" Then 'AndAlso ugc.Key <> "Yprevbal" AndAlso ugc.Key <> "PastDueBalance" 'AndAlso ugc.Key <> "TaxPropertyMasterId" Then
ugc.Hidden = True
ElseIf ugc.Key = "DisplayMatch" Then
ugc.Width = grdResults.Width - 180
ElseIf ugc.Key = "DisplayMatchTypeIcon" Then
ugc.Width = grdResults.Width - 40
End If
ugc.CellActivation = Activation.NoEdit
Next
End Sub
Private Sub grdResults_InitializeRow(sender As Object, e As InitializeRowEventArgs) Handles grdResults.InitializeRow
Dim strDisplay As String
Dim strNumberDisplay As String
strDisplay = "<p><font color=""#393B87""><font size=""+1"">" + Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.EscapeXML(StrConv(CStr(e.Row.Cells("Name").Value), VbStrConv.ProperCase)) + "</font></font></p>"
strDisplay = strDisplay + " " + Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.EscapeXML(StrConv(e.Row.Cells("Address1").Value, VbStrConv.ProperCase))
'strDisplay = strDisplay + "<p align=""right"">Number " + Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.EscapeXML(StrConv(e.Row.Cells("AccountNumber").Value, VbStrConv.ProperCase)) + "</p>"
strDisplay = strDisplay.Replace(StrConv(_searchFileter, VbStrConv.ProperCase), "<b>" + StrConv(_searchFileter, VbStrConv.ProperCase) + "</b>")
'strDisplay = Microsoft.VisualBasic.Strings.Replace(strDisplay, _searchFileter, "<b>" + _searchFileter + "</b>", 1, -1, Constants.vbTextCompare)
strNumberDisplay = "<p align=""right"">Number " + Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.EscapeXML(StrConv(e.Row.Cells("AccountNumber").Value, VbStrConv.ProperCase)) + "</p>"
strNumberDisplay = strNumberDisplay.Replace(StrConv(_searchFileter, VbStrConv.ProperCase), "<b>" + StrConv(_searchFileter, VbStrConv.ProperCase) + "</b>")
e.Row.Cells("DisplayMatch").Value = strDisplay
e.Row.Cells("DisplayMatchNumber").Value = strNumberDisplay
e.Row.Cells("MatchTypeIcon").Value = CsiImageResources.CsiImageList.Images(37)
'e.Row.Cells("MatchTypeIcon").Appearance.ImageBackground = CsiImageResources.CsiImageList.Images(37)
'e.Row.Cells("MatchTypeIcon").Appearance.ImageBackgroundStyle = ImageBackgroundStyle.Stretched
End Sub
