400
How to mask inputs in UltraNodeColumn?
         UltraTree is bound to a datatable having multiple columns.  In this bound tree there are few columns of type Decimal and Int.  I would like to restrict entry of invalid characters in these columns, How can this be achieved?
With WinGrid the same functionality can be achieved by setting ColumnStyle property to double, I have not found similar support in UltraTree. I would like to know if there is any other way to achieve the same functionality.
Thanks for any help,
spm
  • 5
    Verified Answer
    My solution is setting the EditorControl of the column to an UltraMaskedEdit contro. In the UltraMaskedEdit control you have various standard masks to select from including digits only. Just to clarify you don't need to enable editing, just set the UltraMaskedEdit as the EditorControl.
    All the best,
    Stefan
