Is there any way we can generate thumbnail images from pdf documents/tif files/jpeg files using infragistics?
AB.
Thanks for the solution Hristo.
I am just checking about the progress of this issue. Let me know If you need my further assistance on issues related to Infragisitcs Components?
I’ve researched in the web and I found following tutorial in the MSDN forum, where is discussed similar issue:
http://social.msdn.microsoft.com/Forums/en-US/4c380697-4b7f-411d-b501-d9dece02973e/how-to-convert-the-first-page-of-pdf-to-thumbnail-image?forum=winforms
I hope that this will helps you.
