280
Unable to set .Hidden to False on a column
I have an UltraWinGrid where I have set the DataSource to a DataSet that contains 2 tables with a relation set between the two tables on a column named "CodeNumber" as the Parent Column and "ChildColumnNumber" as the Child column.  My grid displays as I would expect, but I would like the column "CodeNumber" in Band(0) to be displayed.  I have a line of code inplace to do this but if I set a break point in the line and inspect the value of Hidden before and after I set it to False it does NOT change.
Is there some way to "override" this behavior?
I'm using the latest versoin of NetAdvantage and VB.Net 2013.
Jamie Irwin
