40
Out of range exception using UltraGrid
I have a grid whose datasource is an IBindingList and that is added to a Usercontrol.  When showing the control that holds the grid I've gotten the following stack trace intermittently.  Note this error does not appear during initialization of the grid, just subsequent attempts to show it among other controls.  Any ideas of what might be going on?
 ************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
   at System.Collections.ArrayList.get_Item(Int32 index)
   at Infragistics.Shared.DisposableObjectCollectionBase.GetItem(Int32 index)
   at Infragistics.Win.UltraWinGrid.VisibleRowsCollection.get_Item(Int32 index)
   at Infragistics.Win.UltraWinGrid.ViewStyleBase.OffsetRows(VisibleRowFetchRowContext& context, Int32 index, Int32 count, Int32 amountToOffset)
   at Infragistics.Win.UltraWinGrid.ViewStyleBase.CreateRowsList_FixedRowsFeature(VisibleRowFetchRowContext& context, VisibleRow parentVisibleRow, UltraGridRow firstSibling)
   at Infragistics.Win.UltraWinGrid.ViewStyleBase.RecreateRowList(RowScrollRegion rsr)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.WillScrollbarBeShown(ScrollbarVisibility assumeColScrollbarsVisible)
   at Infragistics.Win.UltraWinGrid.ViewStyleBase.FitColumnsToWidth()
   at Infragistics.Win.UltraWinGrid.BandsCollection.CalculateBandMetrics(Int32 pass)
   at Infragistics.Win.UltraWinGrid.BandsCollection.CalculateBandMetrics()
   at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetricsHelper()
   at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetrics()
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.ApplyLoadedBands()
   at Infragistics.Win.UltraWinGrid.UltraGridBase.VerifyDataSourceAttached()
   at Infragistics.Win.UltraWinGrid.UltraGridBase.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
   at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
   at System.Windows.Forms.Control.Show()
sbeaudry
